IR 5055
  • ernesto
    • Oct 2011
    • 430
    IR 5055
    HI,
    Does anyone Know if the ir 5000 Transfer/separation corona assembly can work for a Ir 5055?
    I hope to hear from you
    All the best
  • Luther
    • May 2006
    • 682
    Re: IR 5055
    Different part numbers so i would say no
    • vigour
      • Aug 2010
      • 1038
      Re: IR 5055
      It will fit, but I would use it only for a short time, because that unit has had many mods over the years.
      remember to check the wire heights
      • MunsterTech
        • Sep 2014
        • 380
        Re: IR 5055
        yes, it will fit...
        • lazo7
          • 51
          Re: IR 5055
          It works, maybe you'll only have to adyust wire height
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5007
            Re: IR 5055
            You can make star wars on drum surface. Be careful!
