Canon ir c3380 - motor test
  • kuby
    • Oct 2007
    • 1396
    Trying to test the waste toner motor M12. The part-chk says M12 is a developing motor (does not check anyway). But how do you check the operation of this motor. Is the part-chk for the motors wrong? Thanks
    • 16083
    Re: Canon ir c3380 - motor test
    Manual is a mess/
    never could get a straight answer from Canon on Waste Motor M12 check in this model/series/
    but M12 is correct == WASTE TONER MOTOR ASSEMBLY
    • kuby
      • Oct 2007
      • 1396
      • Canon345
        I have found that the Waste Toner Motor (M12) can also generate noise which seems to be amplified through the machine. In Service Mode (COPIER > FUNCTION > PART-CHK), set MTR = 12, then switch on with MTR-ON and you will notice appreciable noise in that part of the machine (front left). A good motor makes very little noise. I tested with the motor right out of the assembly and you can feel the vibration.
