canon ir 7095
  • Saji
    • May 2010
    • 97
    canon ir 7095
    canon ir 7095 showing only printer option, copy option not on display, how to put back the copy function,please help. thanks in advance
    • 16083
    Re: canon ir 7095
    how did it disappear_/? did u do any type of CLEAR ??
    First> In Service Mode Level 2
    make sure
    COPIER>OPTION>BODY>UI-COPY is set to "1" / power off>on
    if set and does not show> do below
    User Mode> Additional Functions > Copy Settings and Initializing Copy Settings.
    Also try, an initialized under Common Settings.
    The machine needs to be turned off / on after initializing the settings.
    The Copy Tab should re-appear in place.
    • Saji
      • May 2010
      • 97
      Re: canon ir 7095
      Thank you Sir teckat
        • 16083
        Re: canon ir 7095
        COLOR HAND.jpgwelcome
