Do you have to tell..or reset the machine when you replace the drum?? If so what is the procedure. .thanks for information. .
ir 9070 drum replacement question
Re: ir 9070 drum replacement question
u mean theimageRUNNER ADVANCE C9070
BLACK DRUM EXAMPLE
<Procedure>
1) Disable the warm-up rotation control.
(COPIER > FUNCTION > INSTALL > AINR-OFF)
2) Turn OFF the main power and replace the Drum (Bk).
3) Turn ON the main power.
4) Forcibly execute the Drum Replacement Mode.
(COPIER > FUNCTION > DPC > DRMRSET /K)
5) Enable the warm-up rotation control.
(COPIER > FUNCTION > INSTALL > AINR-OFF).
6) Execute the following:
Additional Functions (Setup/Register) > Adjustment/Maintenance > Image Adjustment > Auto Gradation Correction > Full Correction**Knowledge is time consuming, exhausting and costly for a trained Tech.**
