IR3300 Cloned HDD gives E602-0004 problem
  • digitalbrain
    i have a IR3300 with Network printing which showed E602 error. I clonned a HDD from another similar working machine (Ir3300N).
    When I switch ON it shows the boot screen and when the loading reaches 50% it shows error "E602-0004"
    it shows the same error when I fit the clonned HDD in the other machine also but it works fine when the original HDD is used.
    Any ideas. Also can I get the latest version of System Software for download ? I am at present holding v33.01 and i hear latest is 45.01
    thanks in advance
    digital brain
  • alex@wocltd.com
    • 430
    so they where both 3300n? (you missed the inclusion on the 1st machine)
    should work then.......
