Jams on 300gsm - 010c, 010d
  • V-P
    • Apr 2011
    • 679
    [Jamming] Jams on 300gsm - 010c, 010d
    I am getting a lot of jams (010d, 010c) while feeding 300 gsm paper through multidrawer A1 into a irac9060.
    I have cleaned all rollers in the paper path and cleaned all the sensors.
    I have replaced all (pickup, feed, sep. rollers) on the multi-deck A1.
    If I use 200 gsm paper or lower gramature - the feeding process goes smooth.
    Is it too much to ask to run 300 gsm ? or I need to change all the rollers in the paper path ?
    Machine has done approx. 1 milion A4.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5012
    Re: Jams on 300gsm - 010c, 010d
    I had the sam problem on our brand new ira 9060 with 300gsm paper. With this kind of paper I was forced to use our old clc5150.
    • V-P
      • Apr 2011
      • 679
      no shit...
      The book says - 300gsm
      • Rachid.Akli
        • Oct 2011
        • 595
        Originally posted by V-P
        no shit...
        Hi to all,
        i think that the book says 300 gsm with the manual bypass. With the multidrawer deck A1, it is limited to 220 gsm only. In the Image Press C700/800, which uses the same muli-drawer option, if you need to use the 300 gsm paper, you need to add the manaul bypass as an option.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • zoraldinho
          • Mar 2008
          • 5012
          Yes, Rachid is right! 52 to 220 g/m2
          • V-P
            • Apr 2011
            • 679
            From the service manual of the multi drawer (page 11):
            This equipment can feed coated/thick and handle 52 to 300 g/m2 media.
            • zoraldinho
              • Mar 2008
              • 5012
              I believe you but check Canon product spec:
              http://www.usa.canon.com/CUSA/assets..._Only_rev1.pdf
              • V-P
                • Apr 2011
                • 679
                On the multi-drawer it says: 52-300 gsm
                • zoraldinho
                  • Mar 2008
                  • 5012
                  • V-P
                    • Apr 2011
                    • 679
                    Those specs are for paper deck NOT multi drawer
                    • zoraldinho
                      • Mar 2008
                      • 5012
                      This is paper deck multi-drawer A1 ! Maybe you mean bypass?
                      • V-P
                        • Apr 2011
                        • 679
                        Let's do it like this:
                        If I am right - you will pay for the dinner when we go to Budapest next time
                        If I am wrong - I will pay for the dinner when we go to Budapest next time
                        • zoraldinho
                          • Mar 2008
                          • 5012
                          Huhh.Probably Im old or blind.
                          dinner's on me!
