iR2200 how to reset Detp ID and Pass
  • Pseudonimk
    Hi, everyone.
    I just trying to install printer kit (network card and Bootloader).
    When I insatall driver on WinServer2000, and try to print test page on the iR2200 screen ask for Departmetn ID and Pass, but nobody knowe what is it, and nowbody used before.
    Is there master reset?
    If master reset is done, what will be with Mail boxes?
    Thanks!
  • Pseudonimk
    I find solution here http://www.copytechnet.com/forums/ca...-defaults.html
    • pinetree
      • Aug 2008
      • 33
      You may reset password ID mode from the service mode, that clears ID mode but if you just want to clear password ID mode from the printer drive, go to ir2200 printer driver, right click your mouse, property, divice setting, click check mark out on accounting then you can print from your pc without putting in ID and password and just leave ID mode for the machine if you have to.
      • iQUISMO
        • Jul 2008
        • 19
        You can clear all passwords from service mode -
        press Additional Functions then 2+8 (simultaneously), and then additional functions again.
        on the service screen,
        go to COPIER
        then at the top, FUNCTION
        then CLEAR
        then PWD-CLR
        then OK on bottom right.
        reboot the machine and you should be all good.
        • Pseudonimk
          Thank you all.
