iR2018 and duplex question
  • DadO
    • Dec 2007
    • 404
    Quite simple but not for me and cant find info simply anywhere .
    DO i need power supply kit Q1 to connect duplex B1 CF2128B001AA on iR 2018?
    I see it in the CBS but im not shure since u need it for 2016....
    THX AHEAD!
  • djbass
    • May 2008
    • 167
    Yes, the iR2018 is a slightly updated version of the iR2016 and just the same requires the power supply Q1 if installing the duplex assembly.
    The iR2018i comes with the power supply & duplex assembly as standard.
    No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
    • Janez
      • Mar 2008
      • 5
      If you have iR2018 , you dont need power supply kit Q1 to install duplex.
      • djbass
        • May 2008
        • 167
        Does the non 'i' version of the iR2018 come with a Q1 already installed then?
        • Janez
          • Mar 2008
          • 5
          No, you dont need PSK Q1 to install duplex. You have on the edge of door prepared connectors to connect duplex.
          Power Supply Kit-Q1 (Required for Finisher-U2 and Cassette Feeding Module-Q1),
          Canon UK - iR2018
