new problem black pages ir9070
  • rdc
    • 53
    while trying to repair raised image problem, encountered a new one.. running copies and it started printing copies like black sheets..if you stop change to print something else the first sheet is clean then it starts getting blacker and gets darker with each copy..stop send print order again first copy clean then it starts again..did a self test started running ten copies and opended door to stop paper feed and it like that before it gets to fuser. thanks again for help..
  • teckat
    • 16083
    Re: new problem black pages ir9070
    check the Primary Charging System, & Potential Control System
    check the DPOT value in service mode (copier>display>Dpot>VDM
    • Rachid.Akli
      • Oct 2011
      • 595
      Hi,
      Check whether the preconditioning lamps are connected.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • rdc
        • 53
        I'll start checking,,, off the glass the copies are clean.
        • rdc
          • 53
          I'll start checking,,, off the glass the copies are clean...dpot...vdm--600v---vdm-p--600v..thanks
          • teckat
            • 16083
            Glass copies are clean & print with no issues.
            So your network prints are the only issue_?
            • rdc
              • 53
              correct..the top half off the glass copies are a little light. but corrects if i adjust dens.but they are very clean..
              • vigour
                • Aug 2010
                • 1038
                1 For the raised print, I would suggest trying a different driver, and updating system software
                2 For print getting darker I agree with Rachid , you didn't plug in your precon or the wire is broken
                • rdc
                  • 53
                  So the lamp in question s the one located directly over cleaning blade??
                  • Rachid.Akli
                    • Oct 2011
                    • 595
                    ​Yes!
                    • rdc
                      • 53
                      Changed lamp from another machine that was know good ..no change ..down loaded driver also no change..is there any way the vibration sensors next to cleaning blade can cause any part of this..see a wire that looks to have bad connection..
                      • rdc
                        • 53
                        changed lamp from another machine that is known to work...no change...down loaded another driver..no change...is there any way the vibration sensors over cleaning blade have any bearing on the issue? it looks as though one wire may have bad connection..no codes though..thanks..but there is a change only half the page is black the other half is a little smutty..thanks..1st from glass.jpg2nd from glass.jpgfrom computer.jpg
                        i made a long extension so i could visually see the lamp come on it doesn't..checked circuit from test harness connector i made to where connector plugs in ,it checked good on both wires..i replaced dc circuit board because of toner waste toner jam up. maybe its gone bad ??thanks again
                        • Canuck
                          Tech Specialist
                          • 1713
                          Originally posted by Rachid.Akli
                          ​Yes!
                          Oh yeah.....been here....
                          • rdc
                            • 53
                            Cancun..what was your solution...????
                            • Canuck
                              Tech Specialist
                              • 1713
                              Is this run LTR or LTRR?
