Canon ir2570i E-000748-4000
  • Chillaholic
    • Oct 2010
    • 40
    [Error Code] Canon ir2570i E-000748-4000
    We have a customer who has an E-000748-4000 error code on his Canon ir2570i.
    So I found this:
    Cause:
    1. Poor connection of peripheral cards or memory DIMMS.
    2. Corrupt System Software.
    Action
    1. Reseat all peripheral cards (UFR Board, Resolution Switching Board, USB I/F Board and the like) SDRAM & Boot Rom on the Main Controller PCB Assembly.
    2. Format HDD and reload System Software.
    All cards, dimms and cables on the PCB have been replugged but the error still exists.
    Is there a possibility to get the firmware for this machine to exclude the case of corrupt software?
    The error just appeared after a toner change.
  • teckat
    • 16092
    Re: Canon ir2570i E-000748-4000
    So I found this:[/LIST][/LIST]
    Try this Board Cleaning & re-Positioning Procedure
    Works 98% of the time for this e748-4000
    your model is in same family as those listed in pub
    Board Cleaning_Board Position-TP07 094.pdf
    or----------------------
    Check or swap or replace the DDI-S Serial Cable before replacing any boards.
    If the cable is poorly connected or otherwise defective an error code of E748-4000 may be the result.
    The cable is pictured below.---------------Cable DDI-S Serial FK2-0732-000
    • Chillaholic
      • Oct 2010
      • 40
      Thanks for your help (and making a photo), we will try to change the cable first and do the "Cleaning & re-Positioning Procedure".
      • Chillaholic
        • Oct 2010
        • 40
        Just wanted to say the cleaning worked for me, error is solved, machine works again, thanks to you.
        • teckat
          • 16092
          COLOR HAND.jpgWELCOME
          • architect
            Format HDD in service mode = HDD clear?
            • teckat
              • 16092
              are u a tech ???
              what is your issue ????
              <HD-CHECK>
              Use it to check and correct the partition you have selected using CHK-TYPE.
              Method of operation
              1) Select the item.
              2) Press the OK key.
              3) See the result (1: OK; 2: NG, hardware; 3: NG, software/corrected sector,
              switched sector).
              <HD-CLEAR>
              Us it to initialize the partition you have selected using CHK-TYPE.
              Caution - if you have selected 0 or 4, the selections will be invalid.
              - if you have selected 1, the SRAM area and the image control data held in the multiple-purpose file storage area will also be initialized.
              Method of operation
              1) Select the item.
              • Andr
                • Nov 2022
                • 1
                [ATTACH]27911[/ATTACH]
                This instruction help me for decide error e000748-400 in canon irc3580ne. Thanks!!
                • teckat
                  • 16092
                  Welcome 😇
