canon irc 2380 E240
  • ernesto
    • Oct 2011
    • 430
    canon irc 2380 E240
    Hi,
    I have a canon irc 2380 in which the error 240 sometimes appears .... it always happens in the morning
    Does anyone know the problem?
    ALL THE BEST
  • teckat
    • 16083
    Re: canon irc 2380 E240
    Originally posted by ernesto
    Hi,
    ALL THE BEST
    [ATTACH=CONFIG]27906[/ATTACH]
    Tip;
    power off>Pull out the Memory DIMMs> clean ends & re-seat / also clean and re-seat the Boot Rom
    >power on
    what is the sub-code xxxx ?
    E240 Error in communication of controller
    0000 Error in communication data. Check connector, check connection of sub PCB in the
    controller box, check / replace DC controller PCB / main controller PCB.
    0001 =There is no response when 3 sec passed since the main controller had sent the pickup request to DC controller during printing.
    0002 =There is no response when 4 sec passed since the main controller had sent the request for image output to DC controller during printing.
    0003 =The engine is activated when jam occurs.
    Before replacing any parts try re-seating all circuit boards that plug into MCON and DCON.
    for some reason> bad fixing film unit can also cause a E240.
    • ernesto
      • Oct 2011
      • 430
      Originally posted by teckat
      Tip;
      >power on
      You are right Mr Teckat the problem was the heater fixing......
      • teckat
        • 16083
