iR7105 Broken Staple Cartridge
  • NgZeng
    • Feb 2015
    • 9
    Our Technician just broke the staple cartridge.
    Any idea how to repair it?
    He says it doesn't work anymore. I don't trust him xD.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: iR7105 Broken Staple Cartridge
    Originally posted by NgZeng
    [ATTACH=CONFIG]27965[/ATTACH]
    Unless the cartridge has broken pieces, it can usually be snapped back together - do you have another to use as reference?
    • NgZeng
      • Feb 2015
      • 9
      Nope, don't have any to use as reference.
      It seems like everything is ok. No broken pieces or anything.
      Is there any picture of the complete cartridge I could use to assemble it back together. I got back the white piece back to it is supposed to be. I just need to put back the metal piece and try it on the machine if it works.
      • vigour
        • Aug 2010
        • 1038
        FC7-1700-000 is the part no. if you need it
        • NgZeng
          • Feb 2015
          • 9
          Thank You, that did help a bit.
          Now there is a problem. Since the staple chain was broken, there were still some staples and they are stuck right now. How should I remove those staples to install the remaining staples from the cartridge. I tried pushing the staples with an exacto blade but it didn't work.
          • vigour
            • Aug 2010
            • 1038
            Sorry I can't help you there
            I recently found an easy way to remove unused staples on other finishers but I have had no opportunity to try on this model
            • NgZeng
              • Feb 2015
              • 9
              Hmm Thank You anyways.
              Would it be ok if I try it without the metal piece back? Will it function correctly and not explode the finisher
