iRADVC 2030 detect usb
  • godyng
    • Dec 2008
    • 40
    Hi,
    i have a Canon irc Advance 2030 with a problem for detect the usb for upgrade system any help will be appreciated ......
  • teckat
    • 16092
    Re: iRADVC 2030 detect usb
    Originally posted by godyng
    Hi,
    On your USB Flash Drive, create a folder and name it the following:
    iAC2030
    Now, when you extract the USB files , the file name will be as shown below:
    USB_iAC2030_v12.02.01 (folder)
    Copy this folder directly into the "iAC2030" folder.
    NOTE: YOU CAN PLACE MULTIPLE FOLDERS INTO THE "IAC2030" FOLDER AND YOU CAN CHOOSE WHAT VERSION YOU WISH TO INSTALL.
    USB_iAC2030_v10.60.01 (folder)
    1. Create a Folder on your USB Flash Drive called "iAC2030".
    2. Extract the downloaded file (example: "USB_iAC2030_Y20.70.01") to the default path of "Canon File Folder" on the C: Drive and then right click on the folder and copy.
    3. Right click in the iAC2030 folder on the USB flash drive and paste the firmware folder into it.
    4. Place the USB Flash Drive into the USB port on the side of the control panel and turn the machine on holding 2&8 to place into Download Mode.
    5. Select the version to download
    6. Select 1:Upgrade
    7. Select 2: OK
    • godyng
      • Dec 2008
      • 40
      iAC2030
      6. Select 1:Upgrade
      7. Select 2: OK
      Thanks , but my problem is can not detect the usb for m/c used to upgrade system 。
      • 20 year tech
        • May 2014
        • 580
        Have you tried a different usb stick ? I have seen it before where the machine doesn't recognize a particular stick.
        • godyng
          • Dec 2008
          • 40
          I put the usb stick to other m/c it can be detect , I also checked the setting for use usb stick in aditional function .
          • teckat
            • 16092
            So the USB Stick & Firmware works in another C2030 ??
            Note:
            :-D
            Service Support Tool v4.33Ez or higher must be used to either flash the>
            imageRUNNER ADVANCE C2030/ C2020 series or to prepare the software for a USB Flash Drive.
            • godyng
              • Dec 2008
              • 40
              Note:
              :-D
              Hi teckat
              I had already prepare the software inside the usb flash drive before ,the problem is this m/c can not detect my usb stick ....
              • godyng
                • Dec 2008
                • 40
                Hi teckat
                After replace the main con 1 yhe problem is solved !!!
                • teckat
                  • 16092
                  • DAG COPIERS & COMPUTERS
                    • Oct 2010
                    • 860
                    [ATTACH=CONFIG]27981[/ATTACH]
                    The only man on planet earth giving the Chinese govt. Sleepless nights.
