Hi all,
I have a strange issue with the above mentioned machine.
The machine keeps restarting continuously, it boots up perfectly till you get to the logon screen, it stays on for about 20 seconds after that. you get just about enough time to login and start pressing a few buttons and then it restarts.
We have tried replacing a few boards, power supplies and so on until we found something that just confused the hell out of us. If you disconnect the fax board the machine does not restart (works perfect). we then assumed that the fax board had issues and decided to replace it, as it obviously had some effect on the machine restarting. we replaced the fax board with a new one. now the machine keeps restarting again (with new fax board). as soon as you disconnect the fax board it works perfect again. We have done firmware just to be sure but no change.
Anyone out there can tell me why this would happen or if they have any ideas as how to get round this, the info will be much appreciated
Thanks,
Thanks,
