canon IR2200 jam code 0105
  • adel_nathan
    • Jul 2011
    • 103
    [Jamming] canon IR2200 jam code 0105
    hi every body
    i have canon IR2200 gives jam code 0105
    when the paper picked up it jams between feed roller and separation roller
    i change the following :
    1- pick up roller
    2- feed roller
    3- separation roller
    4- limit torque ( torque limiter )
    nothing of this action help
    when i remove the torque limiter the machine picked up paper without jamming but take more than one paper at once
    please help me
    thanks
  • Dutchman
    • Jan 2011
    • 58
    Re: canon IR2200 jam code 0105
    Originally posted by adel_nathan
    hi every body
    1- pick up roller
    2- feed roller
    please help me
    thanks
    You might have a faulty clutch on the paperfeed drive system, if not then replace the pickup assembly
    • adel_nathan
      • Jul 2011
      • 103
      cassette no. 2 working good
      replace pickup asse. ????? is there any other solution!!!!!!!!
      • adel_nathan
        • Jul 2011
        • 103
        Please am waiting for help
        Any idea maybe help
        • Dutchman
          • Jan 2011
          • 58
          I would stip the pickup assembly and check if all is ok. Are you using FF5-4552 for pickup and feed and FF5-4634 or FC6-6661 for sep.
          • mido
            • Nov 2011
            • 177
            Replace pick up assembly
            • tongee
              • Nov 2009
              • 50
              hi every body
              1- pick up roller
              2- feed roller
              please help me
              thanks
              try changing gear FS6-0564-000
