ira5xxx
  • alex@wocltd.com
    • 430
    ira5xxx
    Guys & galls - got a Ira5xxx that on any run over say 100 copies loses transfer - if you pause job transfer will return, and occasionally/sporadically for no reason will return.
    see attached - gonna go back and replace secondary transfer roller but a) machine is good in all other aspects b) never had a problem with the transfer roller
    n.b also running latest firmware
    any help would be appreciated!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5000
    Re: ira5xxx
    Hi Alex
    How it looks image quality on transfer belt?
    • onlyinnewfoundland
      • Apr 2013
      • 235
      Re: ira5xxx
      nothing on sims or e-support.......[ATTACH=CONFIG]27986[/ATTACH]
      Alex - I have this same problem on a C5051 @ approx 500k copies.
      I am also returning to replace the secondary transfer roller...perhaps the assembly is damaged in some way that allows the roller to ground out temporarily....
      I'm taking a primary transfer roller kit as well, will update.
      • canon33
        • Jun 2014
        • 65
        Re: ira5xxx
        It's the external xfer roller on the rt door. I replace quite a few for this phenomenon.
        • alex@wocltd.com
          • 430
          Re: ira5xxx
          thanks for the input guys - and no itb image was good, will try 2nd 'ry transfer and see......
          • MunsterTech
            • Sep 2014
            • 377
            Re: ira5xxx
            there is also a MOD for the compression springs for the external transfer roller
            2 x FU8-255-000
            Never seen the transfer that bad before on your images...
