bypass size problem
  • godyng
    • Dec 2008
    • 40
    bypass size problem
    Hi,
    i have a Canon irc Advance 5235 with a problem for detect the monoarch envolope size , i had try to clean the size vr sensor , reposition the 3 point at the tray & service mode to auto adj the tray .... please help !!!!
  • teckat
    • 16083
    Re: bypass size problem
    Originally posted by godyng
    Hi,
    First_ re-enter the service mode door label values for SERVICE MODE>COPIER>ADJ>CST-ADJ>MF-A4R, MF-A6R, MF-A4.
    Then Make sure under >
    Settings and Registration>Preferences>Paper Settings>Register Multi Purpose Tray> is set to "OFF".
    It should be set to OFF to ask what type of paper is being loaded.
    • godyng
      • Dec 2008
      • 40
      Hi Teckat
      This all the service mode I had already try such as
      key in number at front cover before !!
      • teckat
        • 16083
        Hi Teckat
        iRADVC Printing Guide.pdf (703.1 KB)
        is this noted from an application/ when using the Print Driver
        or envelope selection missing on control panel
        or from Printing from a Mailbox Envelope /Paper Source Option is Grayed Out
        In order to print on envelopes from a mailbox, you cannot specify any Finisher modes (Collate, Group, or Staple) in the Change Print Settings screen.
        To make the envelope paper sources selectable, perform the following steps:
        1. On the Change Print Settings screen within the mailbox, the Finisher button will be highlighted in blue.
        2. Press the Finisher button.
        3. Hit the Cancel button.
        4. The Finisher button will no longer be highlighted in blue.
        5. Press the Paper Select button.
        6. The envelope paper sources will now be selectable.
        Multi-Purpose Tray=Paper Size Detection
        The paper width is detected according to output value from the variable resistor that works in
        conjunction with the side guide.
        Since the length cannot be detected, users have to specify the setting.
        look under User Mode settings
        Environment Settings
        โ–  Paper Settings
        Specify Multi-Purpose Tray Envelope Type On,Off*
        Register Multi-Purpose Tray Defaults On,Off*
        * Default Settings
