IR6570 E0121-001
  • satitjangdee
    • Jun 2011
    • 49
    [Error Code] IR6570 E0121-001
    I changed FM4 fan from ir5075 (I think the same) it get the same code .
    I took DC controller from dead machine and insert in another good ir6570, it work OK so DC controller is good.
    I went back to dead one and check wiring from FM4 fan to J108 connector it OK no short or worn.
    Then I put own DC controller back in the machine, it still get code.
    What fault? Help!!
  • wassem
    • Aug 2012
    • 166
    Re: IR6570 E0121-001
    What fault? Help!!
    the new fan has burned the DC
    you should to change with another pair of fan and DC
    • satitjangdee
      • Jun 2011
      • 49
      By the post first I change new fan, code come.
      after that, DC controller moved to another machine, it work OK on that.
      I think fan OK and DC controller OK too.
      • satitjangdee
        • Jun 2011
        • 49
        post closed. DC controller.
        I test again on another machine. Boot up OK but after run about 30 copies so code comes.
