canon imagepress c1+ density
  • dragsprit
    • Oct 2014
    • 27
    Hi
    what are the steps after
    changing all devs on C1+
    How to adjust dens and
    reset to dens to zero and init
    Regards
  • teckat
    • 16092
    Re: canon imagepress c1+ density
    Originally posted by dragsprit
    Hi
    Regards
    did u change all Developing Assemblies
    or just the STARTER in all
    see below----------
    _DO NOT
    perform INISET or INIT after replacing the Starter of the Developing Assembly.
    If INISET or INIT is performed, the initial value of the toner density signal will be set with erroneous data due to staining that occurs on the surface of the ATR Sensor.
    The ONLYtime to perform INISET or INIT on the imagePRESS C1 / imagePRESS C1+ Series is when the ATR Sensor Unit, and the Developing Assemblies (or the starters) are replaced at the same time.
    see attachment
    & don't forget to calibrate the SERVER if attached
    • dragsprit
      • Oct 2014
      • 27
      thanks for reply.
      i only change starters.
      i have found the first pdf file for the developer change.
      TP07 310a.pdf
      and do INIT INISET.
      i change them ,do init 4
      then
      automatic gradation correction (full)
      do i have to make any other settings for correct?
      regards
      • teckat
        • 16092
        thanks for reply.
        TP07 310a.pdf
        and do INIT INISET.
        then
        regards
        No_ if u have a Fiery Server connected> calibrate it
        see attach
        Minimizing E842-0101 and E842-0009 Error Codes.pdf
