Canon ir 2870
  • parry
    • Aug 2025
    [Error Code] Canon ir 2870
    dear all
    i have canon ir 2870 in which while scanning to pc after few pages it gets hang & after 2-3 minutes it shows error code e-0743-0000 whereas it works well during pull scanning & even while copying problem is only when scanning to pc. i have replaced ip board,hdd,reder pcb and its cables,ram and bootrom.
  • teckat
    • 16083
    Re: Canon ir 2870
    Originally posted by parry
    dear all
    ___;-\
    Flex cable_?
    Main Controller_?
    • Canon345
      Re: Canon ir 2870
      Canon has a KB article on this same error in a 6075. During the feeding of originals in the Duplex Color Image Reader C-1 the paper pickup rollers would bounce and hesitate in the original document paper pickup operation and then go into a code of E743-0000.
      Replace the Dadf Driver PCB is what took care of the problem. I know you have replaced parts, just letting you know about this 6075 solution.
      DADF Driver PCB (FM3-7561-000)
      • jayathiyagu
        Re: Canon ir 2870
        Disconnect and then connect the flexible cable used to connect the reader unit and the printer unit.Replace the following as necessary. flexible cable,reader controller PCB, main controller PCB.
