Log In greyed out
  • fatfingers73
    • Feb 2013
    • 219
    Log In greyed out
    Morning all,
    I've set up a few refurbed machine recently where the Log In option in settings is greyed out.
    I fix this by doing a data initialisation.
    I just wondered if there was a quicker way?
    I phoned Canon but they didn't know.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Log In greyed out
    Models?
    • fatfingers73
      • Feb 2013
      • 219
      Sorry, C5051. Cheers.
      Originally posted by zoraldinho
      Models?
      • canonbundy
        • Jun 2012
        • 607
        Originally posted by fatfingers73
        Morning all,
        Should be able to go to SRV MODE > FUNCTION > CLEAR > PWD & this will take it back to default 7654321.
        • fatfingers73
          • Feb 2013
          • 219
          Thanks. I'll try that next time.
          Not sure if that will fix it though. It's not that the password has been changed, it's just greyed out?
          Cheers.
          • ergo
            • Feb 2023
            • 1
            Hi, if you or anybody else would still like to know how to enable admin login if it's grayed out here's the solution:
            1. go to settings/registration
            2. Management settings
            3. User management
            4. Authentication management
            5. change "use user authentication" from OFF to ON
            it should help, at least it did in my case
            cheers
            • zoraldinho
              • Mar 2008
              • 5018
              I have seen this many times with refurbished printers.
              First I cleared them to zero. (data management/initialization of all settings/ 1x with zero data.)
              When restarting, the printer offers to change the factory password.
              • onlyinnewfoundland
                • Apr 2013
                • 235
                It's probably greyed out because they changed the system manager ID password to blank. That automatically logs you out and keeps the login button grey since you are effectively always the administrator.
