irc 1021if error 194
+ More Options
Posts
  • ernesto
    • Oct 2011
    • 430
    Hi,
    I have a canon IRC 1028if, the error 194 sometimes appears, I have replaced the three color cartridges, clean the laser assembly and exchange ITB unit.. but the error 194 sometimes happens.
    does anyone know the problem?
    All the best
  • laitang
    • Nov 2012
    • 627
    Re: irc 1021if error 194
    E194:
    Error in CPR sensor
    Description:
    Cannot detect color displacement detection pattern, detected results fall outside the acceptable range.
    Cause:
    Dirty color displacement detection sensor, color displacement detection sensor fault, DC controller PCB assembly fault, toner cartridge fault.
    Action:
    - Replace ETB unit
    - Terminal assembly fault (check on every contact between the terminals of each color and the high voltage PCB assembly)
    - Replace DC controller PCB
    - Replace toner cartridge
    • ernesto
      • Oct 2011
      • 430
      I replaced high voltage pcb assembly....dc controller......the error still appears.......does anyone know the problem.....?
      I hope to hear from you soon
      all the best
      • teckat
        • 16083
        all the best
        do u have/see any e020's at Power On if so change drum in error (OEM) ??
        Check for a damaged harness that goes to the ETB or replace Harness'
        how is your voltage supply to printer ???
        is it stable and have proper grounding ?
        • ernesto
          • Oct 2011
          • 430
          I did that....I replaced etb and three color cartridges and cleanned the laser unit....:-(
          • teckat
            • 16083
            Harness ??
            • ernesto
              • Oct 2011
              • 430
              Originally posted by teckat
              Harness ??
              Hi,
              I have a canon IRC 1021if, the error 194 sometimes appears, I have replaced the three color cartridges, and exchanged ITB unit..exchanged PAPER PICK-UP ASSEMBLY....exchanged...dc controller.... HIGH-VOLTAGE PCB ASS'Y.....and the last thing I did is exchanged the laser unit and their flat cables..........let me hope, cross my fingers....
              if anyone know the problem, please let me know......
              All the best
              • ernesto
                • Oct 2011
                • 430
                Harness ??
                Hi,
                Finally I put a second hand laser unit and new cables flat of the laser unit. and there has not been error for one week..my fingers are still crossed ;-)
                All the best
