Canon ir 2030 While copying red images are not appearing in the copy
  • geltrons
    • Apr 2007
    • 37
    Good day All
    I am having 5 canon ir 2030 machines. while copying a document with red image or lines it do not appear in copy.
    but while printing it is Ok, while scanning the same document it is Ok
    can some body help me
    regards and thanks in advance
    Thomson
  • teckat
    • 16083
    Re: Canon ir 2030 While copying red images are not appearing in the copy
    Originally posted by geltrons
    Good day All
    Thomson
    Is this when using DF_?
    COPIER>ADJUST>CCD>DFTAR-R set to 1136. Power cycle machine after adjusting setting.
    • geltrons
      • Apr 2007
      • 37
      good day dear
      thank you for the advice
      i will revert the result upon performing the same
      regards
      Thomosn
      • geltrons
        • Apr 2007
        • 37
        Good day
        IR 2030 is not displaying the menu you mentioned.
        service mode display is same as ir 2016 machines
        so i could not not proceed . kindly tell me how with
        this type of machines
        regards
        Thomson
        • teckat
          • 16083
          Good day
          regards
          Thomson
          Sorry, when u mentioned RED , thought u had a iRADC2030
          so u mean> when u place a Color Doc (that has RED) on Glass of your B & W PRINTER , that color will not show up on printed B &W copy
          where / or what are these Glass Originals or are they Copies of Color docs -
          post a copy of issue !!!!!
          U say Printing & Scanning a Color document> the image is and shows solid B & W
          Your not talking about the Color SEND function ==> which requires Color Send Kit-L1
          • geltrons
            • Apr 2007
            • 37
            Yes That is correct
            when we place a Color Doc (that has RED) on Glass of the B & W PRINTER , that color will not show up on printed B &W copy.
            The lighter cyan and yellow are appearing. ( normally these are letter head with logo or any color document)
            But when printing the same document ( a copy of previously stored document or may be any document with red ) it appears clearly
            Hope you understood
            regards
            Thomson
            • teckat
              • 16083
              Yes That is correct
              Hope you understood
              regards
              Thomson
              OK> only when doing Glass/ The original is exposed to light and read using the contact image sensor (CIS) to read the image on a line-by-line basis.
              The flow of analog image processing performed by the contact image sensor (CIS) is as follows:
              The light reflected by the original is collected by the rod lens array.
              - The light is received by the CMOS sensor array.
              - The CMOS sensor array converts the received light to an electric signal and outputs it.
              The CMOS sensor array consists of four channels (units).
              Each channel is provided with an output correction table to output an image signal after performing gain correction for the input brightness signal.
              Contact Image Sensor (CIS)
              1) Enter the service mode.
              Sequentially press the Additional functions key, 2 key, 8 key, and Additional functions key on the operation panel.
              2) Press the arrow key on the touch panel to display "TEST MODE".
              3) Press [OK].
              4) Press the [2] key to display "SCAN TEST".
              5) Press the [1] key to display "SHADING".
              6) Press [OK].
              After completion of the above procedure, the contact sensor output is compensated and parameters are set automatically.
              After completion of automatic adjustment, "OK" is displayed.
              did u clean OPTICS ?
              - Check whether the optical system is free from dew condensation
              - Check whether the optical system (contact sensor/white panel/copyboard glass) is free from scratches, stain, foreign objects.
              You can also adjust the
              Density scale if differences between the image on the original
              and the print occur.
              Printer Density
              NOTE
              The default setting is in the middle ‘5’, on a scale of 1 to 9.
              Press (Additional Functions) ➞ [Common Settings]
              Press [▼] or [▲] until [Printer Density] appears ➞ press [Printer Density].
              Press [Light] or [Dark] to adjust the print density ➞ press [OK].
              Press [Done] repeatedly until the Basic Features screen appears.
              Adjusting the Contrast (Sharpness)
              Place your originals ➞ press [Special Features].
              Press [Sharpness].
              Low
              If you make copies of an original containing halftones, such as a printed photograph,
              using the Photo mode, the moire effect (a shimmering, wavy pattern) may occur. In this
              case, you can lessen this moire effect by using [Low] as the setting to produce a clearer
              copy.
              High
              This setting enhances the edges of original images so that faint or fine text is reproduced
              with a sharper contrast. This setting is particularly suited for copying blueprints and faint
              pencil drawn images.
              NOTE
              • To cancel this setting, press [Special Features] ➞ [Sharpness] ➞ [Cancel].
              • To cancel all settings and return the machine to the Standard mode, press
              (Reset).
              • geltrons
                • Apr 2007
                • 37
                Thank you very much for the quick replay
                i can post you the result by tomorrow only ( i do not have the access to the machine now )
                Any way, Thank you very much
                Thomson
                3) Press [OK].
                6) Press [OK].
                Printer Density
                NOTE
                Press [Sharpness].
                Low
                copy.
                High
                • geltrons
                  • Apr 2007
                  • 37
                  Good day Dear
                  First of all, Thank you very much.
                  executed your step by step instructions and the machines are OK Now
                  It is detecting the Red shade properly
                  Once again Thank you very much
                  regards
                  Thomson Mathew
                  Thomson
                  • teckat
                    • 16083
                    Good day Dear
                    regards
                    Thomson Mathew
                    welcome & good luck
                    • geltrons
                      • Apr 2007
                      • 37
                      welcome & good luck
                      [ATTACH=CONFIG]28573[/ATTACH]
                      Good Day Dear
                      I have an issue with Canon ir 600
                      The customer has transported the machine to a different location and
                      on start up all the error lamps are lit and displayed please wait nothing happens after that
                      pls help
                      regards
                      Thomson
                      • teckat
                        • 16083
                        Good Day Dear
                        pls help
                        regards
                        Thomson
                        You should re-post this as iR600 Issue for a better response, (not under here Canon ir2030 )
                        "Please wait" message appeared on the display.
                        First > make sure >All the fuser electrical connections are confirmed
                        next check Memory> remove>clean & re-seat
                        Make sure the exposure lamp heater has not moved and blocked the light from the exposure lamp to the lamp intensity sensor.
                        Please note the following page from the service manual showing the proper position of the lamp heater.
