ATTENTION Canon Touch Screen Digitizer FIX
  • Penvy
    • Oct 2008
    • 237
    Hey Guys,
    I did a LOT of reading up on how these screens keep failing
    It is the conductive bond to the glass that breaks down.
    The glass is very temp reactive with cold and hot.
    After a time this bond will "slip" and detach slightly.
    to fix this fast and will last is to heat each side evenly "HOT to the touch"
    Like a those cheap oil filled "fin" heaters or careful with a heat gun.
    Heat 1 side at a time to "HOT" to the touch..... NO FLAMES.
    Then quickly press firmly and evenly on a flat cold surface until cool.
    repeat this on all 4 sides !
    Did this on several screens this evening.
    Every one of them then worked!
    Cost of repair...........ZERO !
    I will always give what I got to help out guys
    This ones a keeper!
    P
  • teckat
    • 16084
    Re: ATTENTION Canon Touch Screen Digitizer FIX
    Originally posted by Penvy
    Hey Guys,
    This ones a keeper!
    P
    Good tip,
    Can't imagine pulling out a hot gun in a Manhattan office.
    Security Officer, u won't believe this ,but______
    • Penvy
      • Oct 2008
      • 237
      Originally posted by teckat
      Good tip,
      Even a sm hair dryer will work.
      Just on the edges.
      portable butane soldering pen used very carfuly
      P
