Calibration within Canon IP C1+
  • khattab.al.masry
    • 212
    [Misc] Calibration within Canon IP C1+
    I hope to every one to share ideas with the following case:
    about the following calibration.
    Thanks for share knowledge.
  • Dutchman
    • Jan 2011
    • 58
    Re: Calibration within Canon IP C1+
    If the calibration passed then I would not worry about the lower reading on the yellow. If you want the yellow to be more in line with the other colours then I would add toner in service mode and then reinitialize the yellow and then redo the calibration.
    You could also calibrate using the eye one if your client has one. But then do a shading correction first then a full calibration Printer only and then the calibration. I would clear or initialize the visual values first before storing the new values.
    • teckat
      • 16083
      Stop worrying about curves_:-D
