sleep timer
  • alex@wocltd.com
    • 430
    sleep timer
    any quick way to disable sleep mode for good on image runner advance range?
    thanks!
  • teckat
    • 16083
    Re: sleep timer
    thanks!
    Service Mode > COPIER > OPTION > USER
    SLEEP = Setting of auto sleep function
    Lv.1 Details To set ON/OFF of auto sleep function.
    Use case
    Adj/set/operate method
    1) Enter the setting value, and then press OK key.
    2) Turn OFF/ON the main power switch.
    Display/adj/set range= 0 to 1
    0: OFF, 1: ON
    Default value 1
    Supplement/memo= Transfer time to sleep mode is set in the user mode (Preferences>
    Timer/Energy Settings> Auto Sleep Time).
    SET TO "0"
