imagePRESS C1 color Network Configuration
  • Copier Computer Center
    • Jul 2025
    Can anyone help how to configure network settings imagePRESS C1, because from interface is impossible,
    is any way to reset or restore it ?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: imagePRESS C1 color Network Configuration
    Try with add function>printer setting
    Have machine rip installed?
    • Dutchman
      • Jan 2011
      • 58
      Hi,
      If your machine is without a fiery then you would do the setup by using additional functions and go to network settings, If you C1 has a fiery then use setup on the fiery to alter the network settings. A fiery mounted on the back of a C1 will be found on the touch screen called printer. A stand alone unit you have to push the menu button on the unit. Go to setup on the fiery then enter password ( Fiery.1 ). and do network settings there. Best to do a config page of the fiery by selecting Reboot both when finished.
      Hope this is of assistance
