Cano IR2570ci Scan to file & email setup on Windows 8 PC
  • jonbonse
    • Jun 2009
    • 730
    Hi
    I'm looking for help to setup scan to file and email on a Canon IR2570ci.
    Look forward to any input.
  • teckat
    • 16083
    Re: Cano IR2570ci Scan to file & email setup on Windows 8 PC
    Originally posted by jonbonse
    Hi
    *Manuals for iR3170C/3170Ci/iR2570C/2570Ci
    Windows 8
    • teckat
      • 16083
      Hi
      To scan in a document and send it to an email address:
      1) Place the originals in the feeder and press the SEND button and specify the destination.
      2) Press the SEND SETTINGS and press SEND DOC. NAME to add a name to the document being sent and press OK.
      3) Press SUBJECT and enter the data to the subject line and press OK.
      Note: The subject may be up to 40 characters.
      4) Press MESSAGE and enter a message body and press OK.
      Note: The message body may contain as many as 140 characters.
      5) Press REPLY TO and select the reply-to-address and press OK, then press DONE.
      6) Select the file type of the image from the drop down list. Here you may choose between TIFF, MTIFF, JPEG or PDF.
      7) Press START and the process will begin.
      • jonbonse
        • Jun 2009
        • 730
        Windows 8
        im guessing I need the network guide to set these up however it isn't in the zip file downloaded from the above link................
        • teckat
          • 16083
