E 000110 Error code in Canon IR 2545
  • Subhash Kailas
    • Nov 2014
    • 6
    [Error Code] E 000110 Error code in Canon IR 2545
    Dear all,
    Please help me to solve the problem described here.Paper will come upto Fixing unit and paper jam occurs.When i removed the jammed paper and close the door it shows E000110 error.(Canon IR 2545).Also noted that no image is coming on the drum.I replaced the drum unit,but the error repeats.expecting yours valuable suggestions asap.Thanks in advance.
  • laitang
    • Nov 2012
    • 627
    Re: E 000110 Error code in Canon IR 2545
    E110 : Failure of the Scanner Motor (M21)
    1.Check the cable.
    2.Replace the Laser Scanner Unit.
    3.Replace the DC Controller PCB (PCB4).
    • niyaskarimba
      • Sep 2014
      • 110
      Originally posted by Subhash Kailas
      Dear all,
      Me also have the same issue after re inserted the drum and developing unit.Please help me to solve this issue.Thanks in Advance
      • niyaskarimba
        • Sep 2014
        • 110
        any updates regarding this error code..it happens only when i removed the drum& developing units.How is laser shutter is opening and closing
        • Matoku
          • 173
          hi,
          Maybe this idea heard funny but it nothing wrong to try, I have an experiance on IR4570 that similar disign with your machine. I have tried all the above suggestion with no luck. after I found in this forum about the another solution and its really works
          The solution.
          you check the grounding plat on the registration roller either in contact or not. if not in contact then correct it and have a try.
          this can cause hvt leak detction and drive signal to the dc controller.
          good luck
          • disam
            • Sep 2008
            • 64
            Check also the Laser shutter cable and laser shutter mechanism
            • gksapple
              • Apr 2014
              • 116
              Hi having the same issue in ir 2530 ,u have any solution
              • hafiz
                • Mar 2019
                • 10
                Dear all,
                bro any update for this error . i got also this error after paper jam clear in canon 2520 . change laser unit , drum but same issue . kindly help me
                  this thread has been dead or three years
                  different model
                  you should start your own thread
