E004-0017 on Image Press1110
  • Rachid.Akli
    • Oct 2011
    • 595
    [Error Code] E004-0017 on Image Press1110
    Hi to all,
    I have this issue this morning. The external heating roller assembly has realised more than 1000k. I have already resset the values of FX-EX-RL and FX6EX-U. As i don't have the external heater assembly, i will replace the different elements (rollers, bushings, bearings and thermistors)
    I am looking for any other idea other than what is stated in the service manual below:
    E004 0017 05 Title Heater ON/OFF detection circuit error
    Descriptionof detection
    ON/OFF detection circuit error of the external heat heater 2 (sub)
    Measures 1. Check the external heat heater 2 connector.
    2. Replace the external heat heater 2.*
    3. Replace the fixing heater control PCB.
    * Replace the external heat roller unit in the case of 1,000,000 or more.
    Thanks in advance.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
  • teckat
    • 16083
    Re: E004-0017 on Image Press1110
    Originally posted by Rachid.Akli
    Hi to all,
    Thanks in advance.
    Rachid.
    Check your voltage supply at outlet for proper supply & ground.
    Is printer on dedicated outlet_?
    • Rachid.Akli
      • Oct 2011
      • 595
      Hi Teckat,
      In fact one of the heaters connecting wires was cut. Replacing the ecternal heaters has solved this issue.
      Thanks.
      Rachid
      • teckat
        • 16083
        Hi Teckat,
        Thanks.
        Rachid
        COLOR HAND.jpgWelcome
