IR Adv 7055, Diagnose this image problem for me
  • thadwald
    • Feb 2014
    • 74
    Please
    PG 5 black at 128 density results in the following print:
    The streaks are consistent but there is no pattern to the white dots at all--other than the fact that there are about the same number of them on each sheet.
    The black drum meter is at about 331K sheets, which is at about 66% of it's "life". I can't see any visible defects on the drum, nor issues with the developer module.
    I ran the wire cleaning procedure a few times, no change..
    I have a suspicion that the white spots are the result of one of the wires zapping the drum. Is that possible? If so, what can I try to solve it?
    Can a dirty glass between the laser and the drum cause the streaks?
    Thanks!
  • vigour
    • Aug 2010
    • 1038
    Re: IR Adv 7055, Diagnose this image problem for me
    If the lines only show on black and
    If your lead edge is on the left.
    Then you need new corona wire and grid.
    Not sure about the spots.
    If you run a lot of coated paper, it is possible to get white spots from the clay residue left behind.
    We are supposed to clean all the guides from vertical pickup to reversal and delivery areas with alcohol soaked wipes.
    I have only seen it once
    • SAZ911
      • Mar 2013
      • 193
      Originally posted by thadwald
      Please
      [ATTACH=CONFIG]28300[/ATTACH]
      Thanks!
      Hi,
      The bands on the page are from your corona assemblies (Primary Charge) ​may need re-wiring, also could be your dev if its life is up, so check the counter, and i would say that the spots are from your Pre-transfer corona assy, check for dirt, also may need to be re-wired.
      cheers,
      SAZ911..........
      • thadwald
        • Feb 2014
        • 74
        Originally posted by SAZ911
        Hi,
        cheers,
        Thanks to both of you for your input. I'm new to this and any information is helpful.
        Could either of you explain how a corona wire or grid can cause streaks or spots?
        I had both assemblies out and they looked fine. Also, the manual says not to touch them, so I suppose I will be replacing them.
        • freebyrd116
          • Sep 2012
          • 56
          I agree with the comments regarding primary corona wire being soiled/worn out but a nother possibility could be a problem with a dev that is polluted with hard toner particles inside of it.
          We have had quite a few of these toners that have hardened chunks of toner (some quite small in size) in the mix that cause this issue. This will pollute the dev assy, but will eventually work themselves out if there aren't many of them. I would pull out the black developer assy and inspect the surface coating of toner across the entire length of the dev roller for uniformity. sometime there will be a buildup of this hardened toner in behind the dev blade which can also cause the banding you are seeing.
          If the dev roller looks slightly void of toner coat in the same area as your banding, remove the upper plastic cover and the dev blade and scoop out the clumped toner behind the blade and run your copies again to test for banding. If you dont get all the hardened toner out, sometimes the band will move.
          Also it is very important to never store these toners in a vertical position for nany length of time because the carrier inside the toner will travel to the bottom of the toner causing some of the the specks that you can see in this copy.
          Hope this helps,
          -freebyrd116
          • charm5496
            • 2387
            the wires can be cleaned with a cloth and alchohol or an eraser works well too. Just don't pinch the wire or push too hard or you will break it, and since you probably have no spools of wire or pre-cut wires...USE CAUTION!
            It's not that hard in all honesty. If the grid is soiled and dirty do not use any cloths on it when cleaning. I usually take them to a sink and use soap and water to scrub it down and then rinse with clean water till the soap is gone. Let it air dry before re-installing.
            You will also want to wipe down the side shields on the carona unit as well to remove the film from them.
            • thadwald
              • Feb 2014
              • 74
              Thanks for the input.
              The secondary charge wire caused the streaks. I first tried wiping it using an alcohol soaked pad between the jaws of needle nose pliers. It didn't work. it seems like the surface of the wire was damaged somehow. It had a rough feel to it. I did have a spool of oxidized corona wire on hand, so I was able to replace it, which solved the streak problem. Getting the wire length just right is tricky business!
              I also tried to clean the primary charge gill with an alcohol pad, followed by compressed air to get rid of the lint. It didn't work; I still get the white spots, so now I am waiting for a replacement gill.
              I did check the developer assembly for rocks. It was actually my first suspicion because the problem seemed to occur shortly after replacing the black toner tank. The developer looked perfectly even across the entire roll, so I ruled that out.
              The machine only has about 330K on the meter.
              • thadwald
                • Feb 2014
                • 74
                -freebyrd116
                This is interesting. I haven't solved the spotting problem yet. If this turns out to be the problem, what can I do to remedy it? will shaking up the toner do anything for me?
                • freebyrd116
                  • Sep 2012
                  • 56
                  "if" your problem has been caused by a toner bottle that has had a lot of tiny hard chunks in it it will be difficult to resolve..... The black hopper will be full of the particles and the Dev will also. If you replaced only the Dev and there are still particles n the hopper, it will re-pollute the new black Dev. What have done in the past is run a few hundred solid black prints (pg-5 at 128 or higher) to run a bunch of toner thru the hopper and Dev to help flush the particles out. I have had to remove the Dev and vacuum it out AND replace the black Dev AND toner before at the same time to cure the issue. Did this issue occur when installing a new black toner? Or is the toner bottle near empty? If it's near empty and you shake it you will here sort of a sand/gravel sound in the bottle.
                  • vigour
                    • Aug 2010
                    • 1038
                    Are the spots visible on every colour.
                    Run PG5 of each colour.
                    You have not said how much coated paper you run
                    The main issue with spots is caused by the environment.
                    Do additional functions >adjustment > drum clean
                    Then Run about 35 PG10 double sided
                    see if it clears up
                    My manual says replace primary charger and grid at 150k
                    Not sure why yours says do not touch
                    Dirt or damage on the charger wires will interfere with the charges going to the drum
                    • thadwald
                      • Feb 2014
                      • 74
                      see if it clears up
                      The spots show only on the black. The machine runs very little, if any coated paper.
                      I can try the drum clean procedure tomorrow.
                      • SAZ911
                        • Mar 2013
                        • 193
                        HI,
                        Did you try replacing the pre-transfer corona wire, since you've replaced the corona wire on the primary transfer and have figured out rewiring the corona, you have nothing to lose...
                        cheers...
                        SAZ911..........
                        • vigour
                          • Aug 2010
                          • 1038
                          Now I get it.
                          Do not touch the wires, means, do not run your fingers all over them.
                          If you still have spots, I have more suggestions for you
                          • thadwald
                            • Feb 2014
                            • 74
                            I replaced the primary corona wire and the grid, and now the machine seems to work satisfactory. Those wires are fickle things. I had recurring issues with streaks; no matter how well I cleaned everything, a streak would show up, usually on a new spot. Running the wire cleaning procedure seemed to make everything worse. What finally caused the streaks to disappear, for the most part, is running about 100 PG5 copies. Apparently the wires need to break in before they work well.
                            Just running copies seems to have eliminated the spotting problems as well. They showed up immediately after replacing the wires but gradually disappeared as I ran off copes. I have a suspicion that these were caused by the toner.
                            I still have some light banding going on. There is a possibility of me having put some slight kinks into the secondary wire. I will just let it go for now because the only way I can see it is when running a PG5 on a large, smooth sheet.
                            What is the expected life of the wires? EDIT: I found an answer to this in an earlier post.
                            • vigour
                              • Aug 2010
                              • 1038
                              pre strung wires
                              FL2-8915-000 primary wire
                              FL2-8807-000 pre transfer wire
                              Function> install> TD-AD-4c is recommended at each call
