IR7086 Background
  • Brian8506
    • 1665
    IR7086 Background
    I get light background, mostly towards the rear side of the copy. I'd post pics but it's so light you wouldn't be able to see it. I also have a 7200 along side it that works fine, I've rebuilt the DV as well as switching the dv, drum, and both coronas with the 7200. Most people wouldn't even be able to see it but because it's a print shop, it's an issue. I was wondering if the LED array above the drum could cause that if it was weakening. I'm holding off pulling the laser because there's no room to work here and I would have to move stuff all over the place. I believe I would have to slide the scanner left to get to it if I'm not mistaken. If I lighten the copies, it gets lighter but doesn't go away. Also happens with copies and prints.Any thoughts?
  • Alex ahir
    • May 2012
    • 125
    Re: IR7086 Background
    Unplug pre-charger and print, if its fine than highvoltage board.
