Canon C9075 reboot many times when power up in 10 seconds
  • digitalpressvietnam
    • Jun 2012
    • 51
    My machine reboot many times when power up in 10 second ( when Logo Advance appear in 10 seconds ). I got this problem after replacement new developer unit. Please help me solve this problem. Thanks so much
  • teckat
    • 16092
    Re: Canon C9075 reboot many times when power up in 10 seconds
    Is the Fiery rebooting_?
    Check & turn off Multicast Discovery
    Remove. & reseat all connections, DIMMS on Main Controllers 1 and 2.
    Main Controller 1 Issue_:-\
      • Jun 2012
      • 51
      The fiery not reboot, only machine. When machine engine power on, the monitor show on Logo ImageRunner Advance in 10 second and reboot again. It repeat many times. Do you think RAM in main controller got problem ? I think main controller same as computer. Sometime RAM or Bios got problem, computer auto reboot many times.
        • Jun 2012
        • 51
        Thanks Mr.Teckat, I will try check main controller again
          • Jun 2012
          • 51
          I check RAM and Bios on Main Controller but it still got problem. Machine reboot when power up within 10 to 15 second. I remove RAM for clean but still problem
          • Framarva
            • Sep 2014
            • 2
            Check with open front door, indication error code?
            • Hankster
              • Jun 2011
              • 18
              I have had same prob! Turned out to be main controller! Replaced it! Fixed!
              • teckat
                • 16092
                replace it
                  • Jun 2012
                  • 51
                  replace it
                  Could you please send to me the firmware of C9075 ? I will try to reinstall firmware. I don't think need to replace Main Controller. Before replaced developer, machine worked very good. I think HDD of Main Controller working same as computer. It could not boot in OS. I also tried to open front door and remove drum + developer unit, and then power on. The monitor show Logo Imagerunner Advance and reboot again within 10 to 15 second, not error code
                  • Hankster
                    • Jun 2011
                    • 18
                    The firmware is a huge file! Believe me! All advanced machines have controller 1 issues! Something to try is reseat controller 1. Sometimes the hdd will exhibit the same issue! The boot sequence is also controlled by hdd!!
                      • Jun 2012
                      • 51
                      Thanks so much, I will try it again
                      • Framarva
                        • Sep 2014
                        • 2
                        I had similar problem in IRadv6055, failure Main Controller 1
                          • Jun 2012
                          • 51
                          Yesterday I checked inside main controller 1 and 2, I saw the Led HDD on main controller 2 not working. I think HDD got problem and need to reinstall firmware.
                            • Jun 2012
                            • 51
                            Which PCB got problem ? Anyone help me. Main Controller PCB 1 or 2 ??? Can we refix error on PCB ?
                            • Hankster
                              • Jun 2011
                              • 18
                              Controller 1 is usually the board that goes bad! Nationwide is the source for your board! They are repaired boards! Not real expensive! It's a crapshoot! Welcome to the world of canon!!
