error 197 advance 5051
  • roho
    • Mar 2009
    • 844
    Getting a E197 error continuously. Sub code 0101. Refers to CPU LSI communication, however there isn't any reference in the service manual regarding this signal. The device doesn't have initial rotation, error is immediate. Has anyone else had this error code, or more info on these signals, thanks!
  • wassem
    • Aug 2012
    • 156
    Re: error 197 advance 5051
    by experience in other models i think it related to the heater
    just try to swap the heater of other machine (the two will work)
    • SAZ911
      • Mar 2013
      • 193
      Hi,
      there are many variants of the code E-197 in the manual, all of them say something about comms regarding the dc controller.
      Have you tried replacing the DC controller, as the manual's fix for all of the E-197 codes listed, is to replace the DC controller.
      Cheers,
      SAZ911..........
      • roho
        • Mar 2009
        • 844
        Solved by cutting tie wraps, the wire cables along the main drive assembly. Would still have liked to find out about those signals though, only listed in the manual as error codes, no explanation at all otherwise in the manual.
        Thanks to those who answered!
