can please someone help why the printing looks as above attached. i have cleaned then censers, copier cramera and the copier glass.IMAG0415[1].jpgIMAG0416[1].jpg
Why colored sample? IR7095 is b&w copier!
Appears vertical white line when fotocopy? What about print quality?
How many prints have printer?
Poor text in the middle may cause fixing roller , poor transfer or third thing.Make a force stop and check!
Are you a tech??
It looks like a humidity or paper issue. I would try to isolate the problem by trying a fresh unopened rim of 20ib bond (white). Run 20 sheets portrait then 20 in landscape. Is problem still there? What's machine reporting as humidity level? Swap out sep / transfer chargers from a working machine or use new. I would start here in troubleshooting.
can please someone help why the printing looks as above attached. i have cleaned then censers, copier cramera and the copier glass.[ATTACH=CONFIG]28366[/ATTACH][ATTACH=CONFIG]28367[/ATTACH]
It look like a fusing problem. Try to wipe the print out and check if you can erase or remove it.
