Canon ira6055
  • mramlawi
    • Jul 2011
    • 838
    Canon ira6055
    Dear all my client call me and said that the machine is giving limited function,the feeder need to be checked. Its the first time i face this any one do ?
    Distinguished road makes you jewel in rough
  • wassem
    • Aug 2012
    • 156
    Re: Canon ira6055
    the limited function is related to the finisher not the feeder
    this message can be deleted in user mode ,common setting,function limited off
    the other message says the feeder need to be checked requires the filter glass should be cleaned
    • mramlawi
      • Jul 2011
      • 838
      Re: Canon ira6055
      thanks for your response but extacly what the massage appear on the copier is (Ready to copy functions limited ) the feeder is currently unavailable and at the down of the screen the below massage (the feeder needs to be checked.(caLL SERVICE REP)
      • mosey1100
        • Mar 2009
        • 143
        Re: Canon ira6055
        If you press the Settings Registration button there should be an error code come up which might help troubleshooting what is wrong.
        • vigour
          • Aug 2010
          • 1034
          Re: Canon ira6055
          You Most likely had e302
          • vigour
            • Aug 2010
            • 1034
            Re: Canon ira6055
            A defective scanner unit in the DF will cause that limited function
            • mramlawi
              • Jul 2011
              • 838
              Re: Canon ira6055
              Thank u all,
              my custmer called me and told me it works normally after he turned it of for other day
              • vigour
                • Aug 2010
                • 1034
                Re: Canon ira6055
                Be prepared , it will be back
