Canon ir2420 problem
  • paschalemash
    • Jul 2025
    Hello,when i try to print or make a copy,This message pops up "load the correct paper ie A4 plain paper copy"
    Kindly advice,
    Regards
    Paschal
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Canon ir2420 problem
    Why did you decide to post this here and not the correct forum?
    • MFPTech
      • 486
      Kindly advice,
      Regards
      Paschal
      That's because the print job is asking the machine to print on A4 paper and the machine doesn't have it. Check the page size of the document you are trying to print or select manually the tray you want to print from.
      Sent from my SGH-I337M using Tapatalk
