HELP !!! canon w8400 "filling ink " and stops in middle and freezez
  • Penvy
    • Oct 2008
    • 237
    Guys,
    Please help me out
    Wasting TONS of ink with this
    Moved printer setting
    removed ink carts
    reinstall
    goes thru fill ink cycle and stops in the middle every time on indicator
    Print head is moved over from carriage
    it does ck the nozzels but just stops
    is there a way to "reset" this to stop it?
    get it out of this fill ink mode?
    also the panel freezez once in a while in service mode
    or stops on a service cycle like clean head cycle and just stops
    have to unplug for a long while to get it to respond
    never finishes fill ink cycle !
    print heads are good
    even changed them
    same thing
    I thought there was a general reset
    or is the eprom shot
    Please help
    P
  • SAZ911
    • Mar 2013
    • 193
    Re: HELP !!! canon w8400 "filling ink " and stops in middle and freezez
    Originally posted by Penvy
    Guys,
    Please help me out
    removed ink carts
    reinstall
    even changed them
    same thing
    Please help
    P
    Hi,
    I cant tell you how to "reset" the ink fill process, all i can tell you is that you will have to follow canon troubleshoot guide which basically means you will have to replace parts, and then some...
    i have had this issue on other models and there's always been a different fix for each.
    to check;
    1, head management sensor
    2, purge unit
    3, carriage relay pcb,
    4, ribbon cable (main controller to carriage assy)
    5, ink supply assy (L or R)
    for me atleast, it was always one of the above, keep in mind you will be going through consumables while you try the individual parts, ink , printheads and maintenance cartridges.....
    Good luck.......
    SAZ911..........
    • Penvy
      • Oct 2008
      • 237
      Originally posted by SAZ911
      Hi,
      to check;
      2, purge unit
      Good luck.......
      Thanks for the reply
      The printer was working and printing
      there were no error codes.
      and this one has very low use
      less than 500 banners
      P
