ir1730
  • MunsterTech
    • Sep 2014
    • 376
    [Electrical] ir1730
    I went to a ir1730 asking to load paper, even though paper was present in the cassette. I went to the back plate, took out the Size detect unit and the wire loom that connects to the size detect unit had 2 wires broken off from the connector. I tried in vain to press the wires back into the connector but no luck.
    I checked the parts catalogue and circuit diagram and on the parts catalogue i can see the wiring that i need, but no part number. Is there a specific way for looking for wiring? Not one wiring part in the PC has a part number next to it.
    tks
  • teckat
    • 16092
    Re: ir1730
    tks
    Is this part of a harness_
    Some Circuit diagrams used to show color wire description for connections to their male_female connectors.
    Service manuals are usually poor directions.
    I used to pull of harnesses from strippers, because
    Canon assumed these parts would never be damaged,so they never established a part #'s.
    What page is your part shown on in PC._?
    • MunsterTech
      • Sep 2014
      • 376
      Re: ir1730
      Hi,
      It's on fig 104 the part number is FM4-6571-000, it's the wiring loom for the paper size detect assy on the back plate. Tks
      • MunsterTech
        • Sep 2014
        • 376
        Re: ir1730
        I might just order the size detect unit and hopefully the wiring will come with it. Thanks anyway.
        • teckat
          • 16092
          Re: ir1730
          Cassette Size Detection Switch SW2
          J2241 = 5 PIN CONNECTOR
          u mean the yellow signal wires / don't think is comes with wires
          on single one side small size connectors/ >
          I used to first clean out damaged wire on connector with a exacto knife >then press back in wire that came loose > easy with colored wires u can trace back for eye/continuity check
          not so easy with all Yellow wires
          • MunsterTech
            • Sep 2014
            • 376
            Re: ir1730
            hi Teckat,
            yep its the yellow wires alright, i did try pushing in the 2 broken wires, ive done it before on the ir400, but couldnt get this one working...mite need to find a similar wiring connector from a scrap machine and try that, seems strange that the wiring loom doesnt come as a part number...tks for your help anyway...mucho appreciated.
            • MunsterTech
              • Sep 2014
              • 376
              Re: ir1730
              btw whats an exacto knife?? do you have a pic of it, mite see if they are availiable here in ireland, I have a needle like pin thing that usually works pulling out the old wires and forcing the new ones in...but if the knife is easier mite try and get hold of one.
              • MunsterTech
                • Sep 2014
                • 376
                Re: ir1730
                i googled it...i actually have one at home, will take it in with me and see if i can make a new connection with the wires . tks
                • teckat
                  • 16092
                  Re: ir1730
                  X-ACTO Cut All Knife
                  I use the back reverse side (away from razor edge) to push wire into connector/ need to be careful pushing hard (have cracked some old connectors, small screwdriver can crack connector=result is major headache.
                  Craft supply stores or WalMart has them/also Amazon X-ACTO #2 Knife/
                  the snap fit connector is available as a part/ means u need to trace back 5 wires to test continuity on both ends
                  five wire>from J2241 > to J13L/LH connector in pic ( if able to unplug it)
                  • MunsterTech
                    • Sep 2014
                    • 376
                    Re: ir1730
                    i actually have one of those knifes, ill take it when i go back, trying to find a similar connector on a canon scrap machine, just incase i cant get the wires free and reconnected...tks for your help, ill let you know how i get on with it next week. Tks again
                    • MunsterTech
                      • Sep 2014
                      • 376
                      Re: ir1730
                      hi,
                      just to let you know, i received the Size detect unit and it had the signal wires attached, so saved me a lot of hassle trying to repair the broken wires..tks for your help...appreciated..
                      • teckat
                        • 16092
                        Re: ir1730
                        hi,
                        there are some miracles left in Canon's engineering workforce
