[Error #853] Canon iRc 1028
  • celliers
    • Apr 2014
    • 5
    Hi Peeps
    Maybe someone can shed some light on my issue.
    Basic background.
    2 Desktops connected via CAT network, 3 Laptops connected via wireless to network.
    Printer IP 10.0.0.100 and all PC's/Laptops have same range etc.
    1 Desktop finds printer via install as normal, but once I send Windows test page machine beeps and gives NG #853 code under Job Status Report.
    All other PC's/Laptops have UFR II 21.40 drivers installed, and print perfectly.
    I have tried UFR, PS3, PCL6 drivers. All give the same error.
    Any ideas?
    Regards
    C*
  • Tonersniffer
    • Nov 2012
    • 72
    • ZAcelliers
      • Nov 2014
      • 7
      Re: [Error #853] Canon iRc 1028
      Have tried everything that the manual suggests, hence the post... But thanks for having a go.
      • teckat
        • 16092
        Originally posted by celliers
        Hi Peeps
        Basic background.
        Any ideas?
        Regards
        C*
        this issue is from one Single Desktop only
        • ZAcelliers
          • Nov 2014
          • 7
          Indeed. And the other Pc's have UFR II drivers v21.40. And work 100%...
          • teckat
            • 16092
            PC in question,
            Any restrictions setup on this particular desktop_?
            • ZAcelliers
              • Nov 2014
              • 7
              No. Full Admin rights all services working. Only thing that makes me wonder is it is a all in one PC. And have random issues with these pieces of....
              • teckat
                • 16092
                Did this PC ever print correctly using the UFRII driver_?
                WINDOWS_?
                • Canon345
                  Try cleaning out the drivers. Go to run....printmanagement.msc
                  lmk TY
                  • celliers
                    • Apr 2014
                    • 5
                    Thanks for the ideas. Will have a go at it again and let you know.
                    FYI. UFRII 21.40
                    Windows 7 Pro x64
                    • Canon345
                      FYI. UFRII 21.40
                      Windows 7 Pro x64
                      I can tell you that a registry cleaner repaired this problem too. Next is a reload is the OS.
