canon irc 5185 jam code 0107 paper is stuck in transfer belt.
  • wachman
    • Apr 2014
    • 50
    At a loss hoping someone has seen this. Jamming on all pages intermittently. Code is 0107 no paper at ps25 fuser entrance. I have a blank paper that is looks as if it is clung to the transfer belt by static charge because it is "taken up" by the transfer belt. Have cleaned machiene and contacts. Has any one else run into this?
    Any help is appreciated
  • teckat
    • 16092
    Re: canon irc 5185 jam code 0107 paper is stuck in transfer belt.
    Is printer operating_?
    Last time u changed ITB CLEANING BLADE_?
    How old is Fix Unit_?\ Condition of it's,Preasure Belt
    Have u removed ITB to inspect_
    • wachman
      • Apr 2014
      • 50
      Thanks for the reply teckat!
      found that the ITB was not moving and cleaning blade was flipping stopping the belt. I replaced the cleaning blade with new blade made some good copies however the new blade flipped also.
      1. have not used starting powder previously for this replacement of the ITB cleaning blade is that needed?
      2. questioning the lift mechanics of the itb not reaching correct height allowing blade to flip??
      lower belt on fuser is good 60,000 approx on it
      Ron
      • teckat
        • 16092
        Ron
        ______(
        Never see a flip blade on this series.
        Did u replace just the blade_? or entire cleaner holder_?
        Make sure it's sitting correct.
        New blades usually are pre coated.
        iRC3880 series uses power on blade.=
        lubricant is TKN-0480-000
        How old is ITB sheet_?
        • wachman
          • Apr 2014
          • 50
          I found this
          Have the ITB in the shop found small slice in the belt and marks from the blade flip on the belt after that mark leading to a full stop of the ITB
          Will install new belt and back tomorrow. I will let you know how it turns out.
          I did install a new ITB cleaning blade with entire cleaner holder oem Canon
          Thanks for your help!
          • MFPTech
            • 486
            check also the itb driving gear in the machine.
            • wachman
              • Apr 2014
              • 50
              Thanks for all of the replys !!!
              It turns out it was the small cut in the itb. As the blade would clean it would push in to the cut and the belt would flip the blade stopping the belt. Assuming the static build up from the belt not moving pulling paper to the belt.
              Thanks again for the help!
