Canon Advance C9075 fiery Imagepass A1 error " E000747-1201"
  • digitalpressvietnam
    • Jun 2012
    • 51
    My Canon C9075 got error E000004-0101. I remove User unit for checking. After that, it got error E000747-1201. I checked SDRAM on Main Controller PCB 1 and 2. But it still got that error. Please help me
  • vigour
    • Aug 2010
    • 1034
    Re: Canon Advance C9075 fiery Imagepass A1 error " E000747-1201"
    you may need to change that main controller 2
      • Jun 2012
      • 51
      I refix error E000747-1201 by reseat connector between PCB 1 and 2. But now machine got error E000004-1010 when printing. Anybody have idea ?
      • vigour
        • Aug 2010
        • 1034
        CHECK VOLTAGE
        it should be 208V 15A
        Check if your lamp cable is rubbing against the upper shaft
        E004 is usually a broken lower lamp, or lamp cable . or bad connector on your fixing unit. Fm4_1282. Sometimes you have to change the frame connector too fm4_1378
          • Jun 2012
          • 51
          I replaced power supply board from another machine. Now machine working good. Thanks for everybody's idea so much
