IR 2200
  • maks
    • May 2008
    • 75
    IR 2200
    recently our machine got an error code of 602-001 and just what i have read and learned from this forum i tried first to de-frag the unit..both by pressing nos.1 and 9 at he same time...the unit came back to its normal function after the procedures,THANKS! however the users complained that the machine sometimes took a liitle while to make a copy after pressing start button..what could be wrong?can i ask for suggestions?thanks
  • Oze
    Ricoh Fanboy
    • 1663
    The hard drive is on it's way out.
    Eventually that E602-0001 will turn into an E602-0003 or E602-0004 which is unrecoverable.
    You'll either need to source a pre-loaded drive or use Canon Service Support Tool and load the software yourself.
    • maks
      • May 2008
      • 75
      IR 2200
      thanks for the answer OZE,well i did ordered a new harddisk and im waiting for it....i just hope it arrives earlier b4 the machine breaks down totally....One more ive noticed with these IR 2200/3300 once it reaches the copycount of 150k+this error 602-... occurs...again thanks men!!
      • Oze
        Ricoh Fanboy
        • 1663
        I have iR2200's out in the field that are over 1mil that have NEVER had an E602 and remember...this error code isn't just isolated to iR2200's.
        I've had it on 2270/5000/3200's etc etc.
        Canon got clever with the iR2270 range HDD though.
        They've made the .itf file unable to be edited...so you HAVE to use a genuine drive OR a model that is the same brand as the drive coming out of the machine.
        • maks
          • May 2008
          • 75
          canon IR 2200 HDD
          at last the HDD i ordered finally arrived but the problem is it was manufactured by HITACHI..the SST im using is Ver.3.03 and the system software i have is sys.software 41.01..i looked at the lists of HDD i didnt find the hitachi models..what am i supposed to do now?id like to solved the problem from what i have learned from this site..and this will be my very first chance to do it..i just learned to use the computer lately..can someone out there help me..thanks
          • prada
            • Sep 2008
            • 27
            You could edit the Format.ift file and enter your HDD info?
            • bnmand
              • Sep 2008
              • 383
              using non recommended hdd
              Go to this link as found in another thread of this forum. It was posted by Oze and tells you how to change the ift file using diagrams. Hopefully these instructions help. See http://www.copytechnet.com/forums/ca...html#post37276 for Oze's post
              • maks
                • May 2008
                • 75
                SST system software
                is there anyone who could send me the latest system software for canon IR 2200?because the one i have which was sent by the company doesnt have ANY hitachi HDD models writen on it...all i can see is toshiba,fujitsu,etc..but no HITACHI models of any kind..again i need the help of experts out there...thanks..my e mail address is acgmanila@yahoo.com.ph
                • prada
                  • Sep 2008
                  • 27
                  System software does not contain HDD information, its the format.ift file that holds this info. Try downloading the Format file from more current models, then edit, cut and past into the IR2200 Format.ift file!
                  • Manav
                    MAnav
                    U just need to format the disk again if same problem use sst tool to format & load new software
                    • welshman
                      Technical Support Manager
                      • Oct 2007
                      • 91
                      you can edit it just need to untick read only in folder properties
                      • Oze
                        Ricoh Fanboy
                        • 1663
                        Been there...done that(has B.IT from Monash University)
                        Maybe it's different in the Asia/Pacific region but when you look at the file it's all binary code...nothing at all like a normal .itf file.
                        • maks
                          • May 2008
                          • 75
                          hi guys, im glad to say that until now our machine is still in good running condition even though i havent replaced the hard disk..thats what keep me thinking cause before; our two machines with same model got the same problem and yet after de fragging the problem keep coming back but now with this other one i could say it works out fine after de fragging...
