canon IR2525 duplex jams
  • beagle
    • Mar 2015
    • 7
    Hey gang. I dont see canons often but I have a ir2525 that is consistantly jamming in duplex mode. It has 100k and is very clean. I could not find a "jam code" displayed on the control pannel,but it jams while printing the second side, stops dead in its tracks one sheet is leaving drum area the other is comming down the duplex section just ready to meet the drum for developement.
    Any ideas would be welcome. I suspect a photo interupter?????
  • SAZ911
    • Mar 2013
    • 193
    Re: canon IR2525 duplex jams
    Hi,
    had the same problem on a IRAdv 4025. please note that a ir 2525 and an IRAdv4025 have the same fixing assy. please follow the link below to a previous post on the same issue.
    hope this helps,
    http://www.copytechnet.com/forums/ca...am-0107-a.html
    SAZ911..........
    • BIMAN CHANDRA NATH
      • Apr 2011
      • 42
      hey gang. I dont see canons often but i have a ir2525 that is consistantly jamming in duplex mode. It has 100k and is very clean. I could not find a "jam code" displayed on the control pannel,but it jams while printing the second side, stops dead in its tracks one sheet is leaving drum area the other is comming down the duplex section just ready to meet the drum for developement.
      please check/clean or replace the clutch no 4 -duplex feed clutch in clutch section
      • wellrajive
        • Oct 2013
        • 31
        Hello dear please interchange duplex clutch to m. f tray clutch...... than u know......
        • beagle
          • Mar 2015
          • 7
          Thank You to everyone... I think you may be on to something...I will swap out the clutches and see what happen.
          The Beagle....bow wow
          • beagle
            • Mar 2015
            • 7
            Bingo! swapping the clutches did the trick. Thank you very much.
            Beagle....Bow Wow
