super G3 Fax AH2
  • Tuga
    • Mar 2012
    • 35
    super G3 Fax AH2
    HI
    How changing the number of ringtones to receive faxes
  • teckat
    • 16084
    Re: super G3 Fax AH2
    Originally posted by Tuga
    HI
    Model Series_??
    Usually something like this***depends on model
    The number of rings before the fax board will answer an incoming fax call can be changed through the incoming ring count option.
    1. Select Additional Functions, then Custom Fax Settings.
    2. Select RX Settings, and select Incoming Ring.
    3. Select On. Then you set the ring count from 1-99. Select OK.
    If set to Off, there will be no call tones (will not hear any rings).
    4. Select Done to return to the main screen
    • Tuga
      • Mar 2012
      • 35
      Originally posted by teckat
      Model Series_??
      Hi
      The Model is IRADV C2220i
      • teckat
        • 16084
        Hi
        • Tuga
          • Mar 2012
          • 35
          HI
          Thank you
