Canon IR3035 selects wrong paper size when scanning from the glass only. If you put a 11x17 sheet on the glass to scan, it trys to select A3 size so part of the item scanned in is cut off. If you put 8-1/2 x 11 it trys to select A4. But if you use the feeder to scan these items in, it selects the correct size. If you Copy from the feeder or glass it selects the correct paper size. So only scanning from the glass is wrong. Is there something in settings that I am missing?
ir3035 scan
Tags: None
Re: ir3035 scan
[QUOTE=repeatcopiers;465010]Canon IR3035 selects wrong paper size when scanning from the glass only. If you put a 11x17 sheet on the glass to scan, it trys to select A3 size so part of the item scanned in is cut off. If you put 8-1/2 x 11 it trys to select A4. But if you use the feeder to scan these items in, it selects the correct size. If you Copy from the feeder or glass it selects the correct paper size. So only scanning from the glass is wrong. Is there something in settings that I am missing?[/QUOTE
HI
See if the sensors on the glass bottom are dirty
