canon ir8500 network not working
  • mramlawi
    • Jul 2011
    • 838
    Dear all ,
    i have an ir8500 which was working normally at my client and suddenly its starts to freez and didnt work (stopped copying and printing) given at the display waiting to print ,so after many tries i changed the Main contrall boards and still the same ,till we tried to change board step by step we conclude that the Network card is the problem when we remove it the machine work normally ,so my question is when i bring other used network card and tried to install it to the machine and normally we put the ip and all the settings but the machine is not pinging ,and m sure that the network card is working ,is theres any something must try it to solve this ? should i make clear MMI and try ?
    also same model gave me e602-001 some times when i turn the machine on it works normally and some times the code stuck when i turned the machine on ,once i changed the Main Conrtall board it was made a problem and after i replace it the machine gave me this error !
    Distinguished road makes you jewel in rough
  • tinnyjay
    • Oct 2009
    • 663
    Re: canon ir8500 network not working
    Originally posted by mramlawi
    Dear all ,
    E602-0001 The version of the language file on the HDD and that of bootable do notmatch.
    Update the version of the language file (Language), or install
    the appropriate file.
    Upgrading the firmware or just install language.
    "Who loves the roses,must also bear thumbs"
