ir3045 not adding toner
  • kuby
    • Oct 2007
    • 1405
    Have a ir3045 that was in the shop for repair and replaced the paper delivery delivery assy (FM2-3265) and now the machine will not add toner. Tried the toner install and nothing, tried to test the toner motor in the part check and it works OK. What am I missing. Tried a developing assy out of another machine and it does not work either???
  • ernesto
    • Oct 2011
    • 430
    Re: ir3045 not adding toner
    Hi,
    You can open the toner cover just a little bit to check if the bottle toner is turn around..........what happen with it?
    • kuby
      • Oct 2007
      • 1405
      Never mind it magically started working.
      • ernesto
        • Oct 2011
        • 430
        It would be a good idea checking now if the toner bottle is turning around......
        • kuby
          • Oct 2007
          • 1405
          Yes it is turning..
          • ernesto
            • Oct 2011
            • 430
            If it happens again push the bottle toner out and it fit into the mechanism....it is not uncommon in the older ir 2230 4570.....
            • Canuck
              Tech Specialist
              • 1713
              The claw that uncaps the bottle breaks on them also
