how can customize the colors of canon c9070pro
  • markndreu
    • Mar 2014
    • 34
  • teckat
    • 16083
    Re: how can customize the colors of canon c9070pro
    U have a Canon Controller connected ?????????
    see attach
    Before attempting any hardware replacement test using the following options:
    1. From the printer Settings/Registration select Function Settings.
    2. Select Printer.
    3. Select Printer Settings.
    4. Select Custom Settings.
    5 . From Printer Settings select PCL.
    6. Select CMS(Matching)/Gama.
    7. From Printer Settings select either the Text Graphics or Image option.
    8. Change settings by selecting Gama and test the print job again.
    • markndreu
      • Mar 2014
      • 34
      Very Thanks Teckat I have the controller. Now photocopy is OK with plain paper. I have a problem when I print with heavy paper because transforms the colors of abstruse very
      please help me
      • markndreu
        • Mar 2014
        • 34
        hi everyone, I have a copy machine C9070 Pro, it works very good with plain paper but when i put heavy 1 heavy 2 heavy 3 ect, it transforms the color, it makes the paper darkness.
        • teckat
          • 16083
          set up & use Heavy selection paper when u calibrate
          • markndreu
            • Mar 2014
            • 34
            I have selected but is still the same think
            • markndreu
              • Mar 2014
              • 34
              how can i do the calibration about the heavy paper?
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 5009
                Paper profiles! Read user manual.
                • teckat
                  • 16083
                  also see attach pdf
                  For copy quality to stay consistent when running media heavier than 32lb paper (i.e. 60lb to 90lb) a proper auto gradation using the Heavy 1/2 mode must be performed.
                  The ideal weight to use for this adjustment should be a 60lb bright white sheet of heavy media.
                  Never use any type of glossy coated media to do any auto gradations. Media calibrations should also be done on the Colorpass or imagepass units.
                  Calibration Procedure
                  1. Clean/Adj optics. Clean/inspect optics and white plate/roller. Perform CCD Adj. Some older machines will be CCD Adj (without paper) and newer machines will be DF-WLVL 1-4 with good quality white paper.
                  2. Perform Full Auto Gradation. Now that the optics can properly read the data calibrate the copier. Perform this adjustment on the media being used to print onto. Bright white (98-100) 24lb-28lb is recommended for plain paper over using 20lb bond for more accurate color reproduction.
                  If the customer is using card-stocks perform adjustment on this as well. Generally 32lb-60lb cover is Heavy 1 and 61lb-80 cover is Heavy 2.
                  3. Calibrate the Fiery RIP. Enter calibration mode on copier through Printer, Settings, Functions, calibration, enter Fiery.1 for the password and press OK. If you do not have a densitometer choose the Standard Color Cal Measurement page method under set-up.
                  Use a clean Grey Scale positioned in the top center of the letter size portrait area of the platen glass. Press Calibrate and Yes to print the Measurement Page.
                  Place printed page over the Grey Scale and press Yes and then done to measure. After successful measurement press Yes to overwrite and to it affecting all users.
                  4. Print out a Test Page and Configuration Page. Under Printer, Print Pages, Test Page the Configuration. After verifying print quality place these with the COMPLETED Service Log attached to the machine.
                  5. Verify Customer Knowledge on Calibration Procedure. Ensure that the customer is aware of Steps 2 and 3 for increased quality/reliability and service time.
                  • markndreu
                    • Mar 2014
                    • 34
                    20150404172757_00001.jpg20150404172852_00001.jpg this is the problem that i have with canon 9070pro, if someone knows how to solve it,
                    please give back an answer
                    plain paper heavy paper
                    • teckat
                      • 16083
                      [ATTACH=CONFIG]28693[/ATTACH][ATTACH=CONFIG]28694[/ATTACH] this is the problem that i have with canon 9070pro, if someone knows how to solve it,
                      What print driver are u using_?
                      What application was used to create original_?
                      Are u scanning this document, or direct print from PC.
                      • markndreu
                        • Mar 2014
                        • 34
                        Hi teckat i used the driver A1
                        dokumenti is photo from pc
                        • teckat
                          • 16083
                          A1 ------imagePass
                          PS driver or PCL driver ????
                          PS/UFRII/PCL5e/5c/6 Printer Drivers Version 21.40---see attach pdf
                          did u look at posted info for "Output from Canon PS RIP is Over-Saturated"
                          go into A1 and remove calibrations/ then calibrate Printer then calibrate A1 ==use HEAVY 1 for paper type when calibrating both
                          Graphics and text with identical color values will sometimes appear different based on how the Canon engine and imagePASS, ColorPASS or imagePRESS controllers print different objects. During printing, the engine and controller use different screen combinations on different objects when selecting "Printer Halftone". The "Printer Halftone" setting is configured in the "Image" section of the driver preferences or Command Workstation job properties dialog boxes.
                          When printing text and graphics using the 600DPI setting on Fiery controllers, the following "Printer Halftone" settings will produce output using the same screens on text and graphics and should produce similar colors:
                          1. Resolution
                          2. Gradation
                          3. Error Diffusion
                          4. Pattern 1
                          5. Pattern 2
                          6. Pattern 5
                          Using each of these settings will produce different results so it is important to experiment with each to achieve the desired output.
                          A special case is used when printing text at 1200DPI and color differences between text and graphics may be observed. A screen called Special Error Diffusion is used when printing text objects at 1200DPI and it is the only time the screen is used. When using 1200DPI with text and graphics where matching colors are desired, it is recommended to convert the text to graphic ie. In Adobe products use the Create Outlines option in the Type menu.
                          This content in this article applies primarily to System 8 Release 2 color controllers and newer. The content may however apply to older controllers including black and white.
                          • markndreu
                            • Mar 2014
                            • 34
                            Teckat thank you very much now it's ok thanks but
                            now the copy machine shows in the screen [waster toner is full]
                            and i have Clean the bottle contenier, sensor,
                            in service mode- function- clear - waster toner -ok but the same
                            • teckat
                              • 16083
                              Believe u need to REPLACE the container ? (this is true for C72xx & C92xx series ) not sure of c9070pro)
                              or see below
                              When Replacing the Waste Toner Container///
                              <Follow Procedure>for imageRUNNER ADVANCE C7055 / C7065 / C9075 / C9075 PRO
                              Clearing the Waste Toner Container and Waste Toner Full messages
                              1)
                              Clear the Waste Toner Counter.
                              (COPIER > FUNCTION > CLEAR > W-TN-CLR)
                              2) Set a new Waste Toner Container.
                              3) Execute offset adjustment of the Waste Toner Full Level Sensor.
                              (COPIER > FUNCTION > MISC-P > WTN-OFST)
                              Waste toner full message
