IP Adress changing automatically
  • Dave Braman
    • Mar 2011
    • 16
    When setting the IP Address of the Canon Image Runner 4080, after power off/on it reverts back to a different unreachable address????
  • allan
    RTFM!!
    • 5462
    Re: IP Adress changing automatically
    Is the DHCP setting on or off?
    Whatever
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      If I remember correctly, there is a battery on the controller that maintains IP settings.
      Since this machine is sooooo old, I would think there's a good chance that's it.
      i don't have access to Canon manuals any more (my company is no longer a dealer) so I can't provide you with more than that.
      Please note that I'm drawing on some very old memories, and may be wrong, but this does seem to ring a bell.
      • RAI
        • Feb 2014
        • 44
        Are you working with a Fiery H1 controller? Are you setting the wrong one? Setting a Fiery controller is a number of steps through a menu system.
        • funnykishi
          comp technician
          • Mar 2008
          • 19
          I have same problem in my DC-12 .
          I changed Battery on motherboard of fiery and problem solved.
          • roho
            • Mar 2009
            • 844
            Ive had battery issues as well, but that in my case led to the ip adress being flushed to zeros, however that was sometime ago.
